Введение
Replacing the internal frame on this device is very simple and requires minimal disassembly.
Выберете то, что вам нужно
Lay the device on its back, and rotate so the base is facing away from you.
Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
Lift up the frame with your fingers and push down the rest of the device with your thumbs.
Using the plastic opening tool or your fingers, lift up the frame from any edge.
Remove the frame from the device.
Еще один человек закончил это руководство.
