Введение
This is a guide on how to replace the anchor arm. These arms connect the control arms to the lenses to adjust the focal length.
Выберете то, что вам нужно
Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
Use a magnetic pickup tool or magnetic screwdriver head to remove the guard. The guard should come right off without much resistance.
Locate the panels in front of the binoculars between the middle axle and the viewing lens and simply pry them off with your fingers
Using a flathead screwdriver, unscrew the highlighted screwhead for the control arm.
With your fingers, grab the screw head and pull it out completely once it's unscrewed and replace it with the new control arm if needed.
Identify the panel on the side you wish replace the anchor arm on, as marked on the photo.
Cut the panel open with a knife. Cut the adhesive substance around the panel with the knife and then using said knife, you should be able to lift it off.
Identify the anchor arm. It is circled in red.
Using the spudger, lift the anchor arm. It should come off without much resistance.
Insert the new anchor arm into the now open slot.
