Введение
If the device is unable to turn on, it may be necessary to replace the battery. This guide will show how to remove the old battery, and how to replace it with a new one.
Выберете то, что вам нужно
Place the meter face down, and the back panel and screws can be seen.
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
4 участников успешно повторили данное руководство.
5 Комментариев
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Can't get 2nd screw out!!
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
