Введение
Follow this guide to replace the microphone array on the Sony WH-1000XM4 wireless headphones.
Ensure the headphones are powered off and discharged.
As a precaution utilize the anti-static wrist strap to avoid damaging any of the electronic components.
Выберете то, что вам нужно
Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame. (The right ear cup is pictured, but the process is identical for the left ear cup.)
Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
Pivot the spudger down to unclip the long edge of the ear pad.
Remove the left ear pad. (The right ear cup is pictured, but the process is identical for the left ear cup.)
Remove the foam liner from the left ear cup's speaker. (The right ear cup is pictured, but the process is identical for the left ear cup.)
Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover. (The right ear cup is pictured, but the process is identical for the left ear cup.)
Flip the headphones over, ear cups facing down.
Use your fingers to lift up and flip over the left ear cup cover.
Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
Remove the ear cup cover.
5 человек успешно провели ремонт по этому руководству.
