Char-Broil Grill Burner Replacement
Выберете то, что вам нужно
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: шаг 1, изображение 1 из 1
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: шаг 2, изображение 1 из 2 Char-Broil Grill Burner Replacement: шаг 2, изображение 2 из 2
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: шаг 3, изображение 1 из 1
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: шаг 4, изображение 1 из 2 Char-Broil Grill Burner Replacement: шаг 4, изображение 2 из 2
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: шаг 5, изображение 1 из 1
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: шаг 6, изображение 1 из 3 Char-Broil Grill Burner Replacement: шаг 6, изображение 2 из 3 Char-Broil Grill Burner Replacement: шаг 6, изображение 3 из 3
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
Заключение
2 участников успешно повторили данное руководство.
Dan
Участник с: 10/01/17
155 Репутация
1 руководство автора
Команда
Michigan Tech, Team S5-G1, Galliah Fall 2017 Участник Michigan Tech, Team S5-G1, Galliah Fall 2017
MTU-GALLIAH-F17S5G1
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 579
