Введение
Power cords on appliances such as this can get damaged easily. Instead of throwing it out, consider replacing the cord. As with any other electrical device, a damaged power cord can cause a fire or injury, so this guide can assist in reducing that risk.
Выберете то, что вам нужно
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
Carefully flip the device right-side-up while grasping the top and bottom pieces.
Remove the spade connectors from the switch by pulling only on the connector, not the wire.
Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
Еще один человек закончил это руководство.
