Choker Necklace Jump Ring Replacement
Выберете то, что вам нужно
  1. Choker Necklace Jump Ring Replacement, Jump Ring: шаг 1, изображение 1 из 1
    • The materials include: two long-nose pliers, a jump ring, and the necklace you are repairing.
  2. Choker Necklace Jump Ring Replacement: шаг 2, изображение 1 из 2 Choker Necklace Jump Ring Replacement: шаг 2, изображение 2 из 2
    • Grab the jump ring at the opposite side of the slit with your fingers (or long-nose pliers if the jump ring is too small to handle). Then, with your other hand (or long-nose pliers), grab the clasp at the end that's opposite of the loop ring hole.
  3. Choker Necklace Jump Ring Replacement: шаг 3, изображение 1 из 1
    • Thread the loop ring through the tiny hole that's protruding from the bottom of the clasp. Continue to hold onto the loop ring without letting the clasp fall off and remove the opposite hand/tool's hold on the clasp.
  4. Choker Necklace Jump Ring Replacement: шаг 4, изображение 1 из 2 Choker Necklace Jump Ring Replacement: шаг 4, изображение 2 из 2
    • Without releasing the hold on the loop ring and clasp, use the opposite hand to grab the end of the necklace that doesn't have the long chain attached to it. Carefully place the necklace end on the loop ring and release, allowing the loop ring to thread through it without having to move the loop ring.
  5. Choker Necklace Jump Ring Replacement: шаг 5, изображение 1 из 2 Choker Necklace Jump Ring Replacement: шаг 5, изображение 2 из 2
    • Going from the sides, use the long-nose pliers to slowly and gently pinch close the loop ring as seen in the picture. Loop ring may break If done with too much pressure.
  6. Choker Necklace Jump Ring Replacement: шаг 6, изображение 1 из 2 Choker Necklace Jump Ring Replacement: шаг 6, изображение 2 из 2
    • Going from the top, squeeze the jump ring together using the long-nose pliers. This will keep the loop ring from opening back up without having to solder it.
  7. Choker Necklace Jump Ring Replacement: шаг 7, изображение 1 из 1
    • Once the jump ring is closed, secure the clasp on the other end of the choker.
  8. Choker Necklace Jump Ring Replacement: шаг 8, изображение 1 из 1
    • The repair is finished.
Заключение
Now that the jump ring is secured, the fixed necklace can now be worn.
Еще один человек закончил это руководство.
Katherine Gemmingen
Участник с: 02/07/19
187 Репутация
1 руководство автора
Команду
McKendree University, Team S1-G1, Quinn Spring 2019 Участник McKendree University, Team S1-G1, Quinn Spring 2019
MCKU-QUINN-S19S1G1
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 539
