Введение
This guide will walk users through replacing the cooling fan of the Chromebook x360 14-da0011dx. Fans accumulate debris and dust over time, causing malfunction or reduced function. If possible, clean fan debris and retry connection before replacing the fan altogether.
Выберете то, что вам нужно
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
Disconnect the fan cable from the motherboard.
Carefully remove the fan from the computer.
Еще один человек закончил это руководство.
