Введение
If a Google Chromecast is dropped, there is a chance the case will lose integrity and crack or become deformed. When removing the case, the power button can become dislodged. Be sure to not lose this piece.
Выберете то, что вам нужно
Place the Google Chromecast face down (with text not showing) on a flat surface.
Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
5 участников успешно повторили данное руководство.
Один комментарий
que hacer si el pin de centro de carga se despredio como pegarlo o soldarlo?
