Введение
All you need is a plastic opening tool and tweezers! With these you can change your camera!
Выберете то, что вам нужно
Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
After separating the case and screen, turn your screen face down so you can see the internal parts!
Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
