Введение
A guide to show how to replace LCD Screen in the Chumby One.
  1. Remove 4 self-adhesive plastic dots covering the screw holes.
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Remove the four 2mm screws with a Phillips screwdriver.
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Remove the back and bottom cover.
    • Remove the back and bottom cover.
  4. Disconnect the battery connector from the motherboard with a plastic opening tool.
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  6. Disconnect the microphone connector from the motherboard with a plastic opening tool.
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  7. Remove the display ribbon cable from its socket with a plastic opening tool.
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  8. Remove the volume knob from the side of the Chumby One with a plastic opening tool.
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  9. Remove the four 6mm screws using a PH000 bit on the inner chassis.
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  10. Remove the inner components from the outer shell.
    • Remove the inner components from the outer shell.
  11. Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  12. Remove the metal shield from the front case using a plastic opening tool.
    • Remove the metal shield from the front case using a plastic opening tool.
  13. Remove the LCD screen from the outer case using a plastic opening tool.
    • Remove the LCD screen from the outer case using a plastic opening tool.
Заключение
Jordan Houchins
Участник с: 27.03.2017
401 Репутация
Автор 4 руководств
Команда
IUPUI, Team S3-G3, Baechle Spring 2017 Member of IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 65
