Cingular 8125 Speakers Replacement
Выберете то, что вам нужно
    • Hold the phone with the back (camera side) facing you.
    • Press on the battery cover until it slides off.
  1. Cingular 8125 Speakers Replacement: шаг 2, изображение 1 из 1
    • Lift up the black tab that sticks out on the battery's side until the battery is pulled out.
    • Using the iFixit Opening Tool, pull on the phone's camera cover until it pops off.
  2. Cingular 8125 Speakers Replacement: шаг 3, изображение 1 из 1
    • Remove the four black Torx head screws in each corner.
  3. Cingular 8125 Speakers Replacement: шаг 4, изображение 1 из 1
    • Pull on the back cover of the phone with the iFixit opening tool until the green motherboard is revealed.
  4. Cingular 8125 Speakers Replacement: шаг 5, изображение 1 из 1
    • Remove the black plastic piece from the motherboard by gently pulling it off.
    • Align the white squares on the motherboard and the speakers.
    • You'll know they are lined up correctly when the speaker's wires face the motherboard's center.
    • Press down on the white squares until they snap together.
  5. Cingular 8125 Speakers Replacement: шаг 6, изображение 1 из 1
    • Place the back cover of the phone over the motherboard.
    • Check to be sure the speaker's black piece is against the holes in the back cover.
    • Screw the four Torx head screws with the 64 Bit Driver Handle to connect the back cover to the motherboard.
    • Press the camera cover down on the back cover until it snaps into place.
    • Line up the copper terminal on the battery with the terminal on the phone, then press the battery back into place.
    • Make sure the black tab sticks out.
    • Slide the battery cover over the camera cover until it snaps back into place.
Заключение
Laura Kimberly Simonds
Участник с: 09/24/12
301 Репутация
Автор 2 руководств
Команда
University of Maine, Team 1-1, Diaz Fall 2012 Участник University of Maine, Team 1-1, Diaz Fall 2012
UMAINE-DIAZ-F12S1G1
4 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 371
