Введение
Use this guide in order to remove the housing of the phone.
Выберете то, что вам нужно
Locate the horizontal grip located on the back cover of the phone.
Slide the back cover down and off of the phone.
Insert a plastic opening tool into the battery release point located above the battery.
Pull outwards in order to release the battery.
Locate the 5 screws holding the body of the phone together.
Using a Philips head screwdriver, twist counterclockwise to remove the screws.
Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
