Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly
Выберете то, что вам нужно
  1. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the two screws on back side: шаг 1, изображение 1 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the two screws on back side: шаг 1, изображение 2 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the two screws on back side: шаг 1, изображение 3 из 3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove top cover: шаг 2, изображение 1 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove top cover: шаг 2, изображение 2 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove top cover: шаг 2, изображение 3 из 3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the three screws on front side: шаг 3, изображение 1 из 2 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the three screws on front side: шаг 3, изображение 2 из 2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the inner metal shield: шаг 4, изображение 1 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the inner metal shield: шаг 4, изображение 2 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove the inner metal shield: шаг 4, изображение 3 из 3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
  5. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove black and silver screws: шаг 5, изображение 1 из 1
    • 1. Use the Phillips #1 Screwdriver to remove the black screw.
    • 2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
    • You should remove just only one silver screw - the second one is holding just cooling plate.
  6. Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove CPU module: шаг 6, изображение 1 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove CPU module: шаг 6, изображение 2 из 3 Cisco 878 Integrated Services Router SHDSL Filter Module Disassembly, Remove CPU module: шаг 6, изображение 3 из 3
    • Gently pull the module up to disconnect two connectors underneath.
    • Be careful and don't damage 4-pin connector (marked RED).
Заключение
Еще один человек закончил это руководство.
Jiri Altman
Участник с: 05/03/16
1 512 Репутация
Автор 9 руководств
Команда
4k20 Repair Team Участник 4k20 Repair Team
Community
2 членов
Автор 17 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 234
