Введение
This guide shows how to remove and replace the control switch on the Clarke EZ-8 floor sander.
Запчасти
Slide the collar on the control link arm up until the two halves of the arm detach from one another.
Pull up on the latch at the bottom of the handle assembly, then remove the retaining plate from its slot in the handle.
Use a socket wrench with a deep 9/16" socket to remove the retaining nut and star washer from the control switch toggle.
Use a Phillips #2 screwdriver to remove the six screws on the control housing—three on either side.
Lift the control housing up and swing it open so the wiring panel inside is accessible.
Use a #2 Phillips head screwdriver to remove the following three screws from the wiring panel:
Two 10-32 x 3/8" screws
One 8-32 x 3/8" screw
Remove the ring and fork terminals from the screws.
Pull and gently wiggle the control switch to remove it from its mounting hole in the control housing.
Еще один человек закончил это руководство.
