Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-4 are sourced from a guide that's marked as in-progress.
    Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: шаг 1, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Safety precautions: шаг 1, изображение 2 из 2
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 2, изображение 1 из 1
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 3, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 3, изображение 2 из 2
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 4, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 4, изображение 2 из 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement, Remove the eccentric arms: шаг 5, изображение 1 из 1
    • Use a 3/4 inch socket to remove the two bolts on the eccentric arm.
    • You may need to use a 3/4 inch wrench in combination with the socket wrench to hold the nuts in place.
    • During reassembly, apply threadlocker to the bolt securing the eccentric arm to the blade arm.
  6. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 6, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 6, изображение 2 из 2
    • Remove the plastic washer from between the eccentric arm and the blade arm.
  7. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 7, изображение 1 из 1
    • Lift the eccentric arm away from the blade arm.
  8. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 8, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 8, изображение 2 из 2
    • Remove the steel washer from the eccentric shaft.
  9. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 9, изображение 1 из 1
    • Remove the plastic washer from the eccentric shaft.
  10. Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 10, изображение 1 из 2 Classen Sod Cutter HSC18AHD 2018 Eccentric Arm Replacement: шаг 10, изображение 2 из 2
    • Remove the eccentric arm and plastic washer from the eccentric shaft.
    • Repeat steps 5–10 for the other eccentric arm.
    • During reassembly, use a grease gun to add grease to the bearings through the two Zerk fittings on each eccentric arm.
Заключение
2 участников успешно повторили данное руководство.
Sam Omiotek
Участник с: 02/25/19
72 472 Репутация
Автор 288 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 30
За всё время: 1,430
