Введение
Follow this guide to remove and replace the cutting blade for the Classen Sod Cutter SC18AHDCA.
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Use a 1/2" socket wrench to remove the six 1 inch-long bolts securing both ends of the blade. You may need to use a 1/2" combination wrench to hold the nuts in place.
Grasp the back of the blade and slide it away from the mount.
Remove the blade.
2 участников успешно повторили данное руководство.
