Введение
There is nothing quite like the feeling of riding a Razor RipStik Classic Board; however, if your Razor RipStik has lost its ability to twist seamlessly, you most likely have a worn-out torsion bar, which requires replacement. With this guide, you will be able to replace the torsion bar on a RipStik Classic Caster Board.
A functional torsion bar provides the resistance needed for the RipStik to twist along with the rider’s hips. When you have been riding for quite some time, eventually, the torsion bar will become tight making it difficult to ride. A worn-out torsion bar will make it difficult for the plates to twist oppositely. If you notice that your RipStik is not twisting like usual, consider checking for rust. If you continue to notice the RipStik is not twisting as seamlessly as normal, you should replace the torsion bar.
A faulty torsion bar can cause an injury. If your torsion bar has rust, take appropriate precautions.
All it takes is a couple of minutes and minimal skills to ensure the safety and enjoyment of your next ride.
Выберете то, что вам нужно
Use a 5 mm Allen Wrench to remove the two bolts attaching the front and back deck platforms to the torsion bar.
Pull the torsion bar and torsion ball shell from each deck platform to separate them.
Slide the damaged torsion bar out of the torsion bar shell.
Clean the torsion bar shell and inner deck platforms of dirt and rust with soap and damp towel.
Apply white lithium grease to the inside of the deck platforms and torsion bar shell.
Insert the new torsion bar into the torsion bar shell.
Align the threaded holes into the original position with the bolt holes.
Reattach the two 5 mm bolts connecting the torsion bar and deck platforms with the Allen wrench.
