Запчасти
Никакие детали не требуются.
  1. Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Press the eject button to insert the tray
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Unscrew the 3 screws in the back.
    • Unscrew the 3 screws in the back.
  4. Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
    • Pull the outer case upward and then towards you.
  5. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  7. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  8. Locate the white clip that attaches the cord to the motherboard Grasp clip and squeeze to release Lift up and remove power cord
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  9. Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray Remove the three screws holding in the DVD tray
    • Remove the three screws holding in the DVD tray
  10. Remove the power cord and first two ribbons by pulling them directly out of their sockets. Remove the power cord and first two ribbons by pulling them directly out of their sockets.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  11. Gently lift the DVD tray off of the motherboard. Gently lift the DVD tray off of the motherboard.
    • Gently lift the DVD tray off of the motherboard.
  12. Spin small gear shown right to begin opening the tray. There should be relatively little resistance in the gear. Spin small gear shown right to begin opening the tray. There should be relatively little resistance in the gear.
    • Spin small gear shown right to begin opening the tray. There should be relatively little resistance in the gear.
  13. Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser. Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser. Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
    • Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
  14. Use the cotton swab to wipe off lens Use the cotton swab to wipe off lens
    • Use the cotton swab to wipe off lens
Заключение
11 участников успешно повторили данное руководство.
Mitchell Hart
Участник с: 21.01.2011
834 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 3-30, Regan Winter 2011 Member of Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 членов
Автор 8 руководств
Комментариев: 4
Thank you Mitchell for your clear, concise directions and photos. I was able to dismantle my Samsung DVD-VCR player Model DVD-V2000. It recently quit playing DVD’s, showing a “No Disc” message. It will play CD’s just fine. I cleaned the laser and reinstalled but still no DVD, just CD’s will play. I like the machine and may look into a replacement DVD assembly if I can find one for a reasonable price. Otherwise I’ll upgrade to a new combo unit with the latest bells and whistles. Best wishes, Bill
sherlockbill - Ответить
I successfully fixed the "No Disc" issue on a DVD/VCR model DVD-V5000. Your guide helped and it was basically the same process. I used a foam tip (well a makeup applicator to be more precise) instead of a cotton tip, because it is less likely to leave anything behind like cotton strands. All works now, thanks!
bmtankard - Ответить
Hello Mitchell,
Can I use this procedure to clean the laser of a Samsung D530 dvd player?…..mine also does it’s own thing and generally doesn’t respond to command same as the other users .
Thank you
Brian
Brian Hepke - Ответить
Hello Mitchell, i tried this procedure on an LG 8600c DVD player, basically same procedure and managed to get to lens cleaned it and reassembled everything but now DVD tray doesn’t want to come out and obviously I get the NO DISK message as I cannot load and DVDs. Can you help please ?
Jennifer Farrugia - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 5
За 7 дней: 51
За 30 дней: 211
За всё время: 32,024
