Введение
If you are having trouble adjusting the headband on your Skullcandy Mix Master DJ headphones, you may need to simply clean the slider tracks to remove any obstructions. This guide will show you how to that in just four few easy steps.
Выберете то, что вам нужно
Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
Rotate the headphones so that one of the speaker cups are facing you. Remove the four Phillips 3 mm screws along the headband cover.
Using a moist Q-tip or small towel, carefully wipe the inside of the headband sheath.
