Выберете то, что вам нужно
Going to pick apart this Multicom/Clevo W550su and see if I can fix the charging port.
I startet with removing the batteries
Next I remove the panels covering the back
Еще один человек закончил это руководство.
2 Комментариев
To reassemble you must use thermic paste right?
You should always apply new thermal paste between the CPU and it's heatsink. And if applicable between the GPU or other chipsets and their respective heatsinks.
