ClickN Kids Tablet Touch Screen Display Replacement
Выберете то, что вам нужно
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: шаг 1, изображение 1 из 1
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
  2. ClickN Kids Tablet Touch Screen Display Replacement: шаг 2, изображение 1 из 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
  3. ClickN Kids Tablet Touch Screen Display Replacement: шаг 3, изображение 1 из 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
  4. ClickN Kids Tablet Touch Screen Display Replacement: шаг 4, изображение 1 из 2 ClickN Kids Tablet Touch Screen Display Replacement: шаг 4, изображение 2 из 2
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
  5. ClickN Kids Tablet Touch Screen Display Replacement: шаг 5, изображение 1 из 2 ClickN Kids Tablet Touch Screen Display Replacement: шаг 5, изображение 2 из 2
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
  6. ClickN Kids Tablet Touch Screen Display Replacement: шаг 6, изображение 1 из 1
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
  7. ClickN Kids Tablet Touch Screen Display Replacement: шаг 7, изображение 1 из 2 ClickN Kids Tablet Touch Screen Display Replacement: шаг 7, изображение 2 из 2
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
Заключение
4 человек успешно провели ремонт по этому руководству.
Kevin Finney
Участник с: 03/22/15
562 Репутация
Автор 4 руководств
Команда
Baylor, Team 4-4, Williams Spring 2015 Участник Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 8,148
