Введение
The fuse is part of the power cable. It burns out under high electrical current to prevent damage to the radio. The power cable should be disconnected from the power source before starting this guide.
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Simultaneously push the fuse container together and rotate counterclockwise.
Еще один человек закончил это руководство.
