Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This process is easy, but will require some soldering.
Запчасти
Детали не указаны.
  1. Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  5. Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
    • Use a soldering iron to remove the connection between the red wire first then proceed to the black wire.
  6. Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
    • Use the PH00 screwdriver to remove the six 0.25 cm screws circled in the image.
  7. Remove the ribbon cables by gently lifting the black tabs and pulling out the cable.
    • Remove the ribbon cables by gently lifting the black tabs and pulling out the cable.
    • This will allow the user to lift and remove the motherboard from the tablet.
Заключение
Еще один человек закончил это руководство.
Ian Swett
Участник с: 11.03.2015
597 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-3, Panko Spring 2015 Участник Colorado Springs, Team 5-3, Panko Spring 2015
UCCS-PANKO-S15S5G3
3 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 335
