Введение
The purpose of this guide is to communicate steps on how to replace or repair the controller ports on a ColecoVision.
Запчасти
Никакие детали не требуются.
  1. Flip the ColecoVision over with the pegs facing the ceiling.
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. Carefully remove the bottom of the ColecoVision out of the top. I would recommend running a metal spudger along the rim of the case to remove the bottom.
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver. Remove the casing and put it to the side.
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  5. Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver. Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  6. Flip the motherboard over and locate the two controller ports. Using a soldering iron, desolder the controller ports. Refer to this soldering technique guide for reference.
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Заключение
Bobby
Участник с: 17.10.2018
353 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team S1-G2, Rose Fall 2018 Member of UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 9
За всё время: 73
