Введение
Nothing ruins a trail ride faster than a throttle that refuses to snap back. Most riders run into this at some point: dirt, rain, and normal wear cause the throttle cable or housing to stick. Over time, these components can become worn, sticky, or damaged — making the bike difficult or even unsafe to operate.
This guide shows you how to replace the entire throttle assembly on a Coleman CT200U‑AB minibike so you can get back to reliable, responsive riding in under an hour.
Key Terminology
- Throttle housing – 2‑piece plastic shell that holds the grip and cable end on the handlebar.
- Ferrule – The metal collar crimped to the throttle‑cable sheath.
- Carburetor linkage – The lever on the carb accepting the inner cable.
- Free play – Small rotational slack at the grip (1–2 mm) before the cable pulls.
Hot engines & moving parts can cause serious injury.
‑ Let the engine cool completely.
‑ Remove the spark‑plug boot before you start.
‑ Wear safety glasses and gloves at all times.
Выберете то, что вам нужно
We should remove seat for better access.
There are two 8mm bolts holding the seat down to the frame (Picture 2)
Remove, them and pull up and the seat should just come off, making it much easier to access components of the throttle assembly
Step 1 Completed
Once the seat is off you can see the spark plug wire.
Step 2 Completed
Inspect the Throttle Assembly Check for visible damage to the throttle cable, grip, and housing. Look for frayed cables or sticking in the throttle twist mechanism.
As you can probably see this cable is pretty frayed up. So it must be replaced
Remove the Screw in Photo 1 with the Philips head screwdriver.
Slide the rubber grp off
Take off the throttle clamp to expose the throttle cable sheath.
Step 4 Completed
From the throttle assembly located on the engine remove the nut screw holding the cable in place (photo 1)
Use the screwdriver to take off.
Step 5 completed
Lay out your new throttle kit in front of you. Check to make sure you have a grip, throttle cable and clamp.
Take apart throttle clamp with screwdriver.(Picture 2 & 3)
Install the new wire onto the new throttle.
First insert the ferrule into its recess.
Step 7 completed
Insert the ferrule into its recess. (Pic 1)
Hook the barrel into the grip drum. (Pic 2)
Check that the cable rides in the molded channel.(pic 3)
Step 8 completed
Prepare the grip and throttle for installation on the handlebars. (Pic 1)
Apply a drop of thread‑locker to each bolt. Clamp the two housing halves together (Pic 2)
Slide the grip on (pic 3)
Step 9 Completed
Secure the throttle assembly onto the handlebars.
Slide the grip on; tighten the set screw. (Pic 2)
Step 10 completed
Attach the cable sleeve to the throttle assembly on the engine.
From the throttle assembly located on the engine place the throttle cable then tighten the screws.( Pic 2 and 3)
Step 11 completed
Adjust the Throttle Tension Ensure the throttle snaps back properly when released.
Adjust the cable tension if necessary, using the adjustment screw near the carburetor. Refer back to the previous step if necessary.(Pic 2 & 3)
Attach spark plug in (pic 1)
Put seat Back on. (pic 2)
Grip it and Rip It
2 человек успешно провели ремонт по этому руководству.
