Введение
Power not reaching your motherboard? Does the lantern not illuminate even though its been charged? Check out this guide on how to remove and replace the battery!
Выберете то, что вам нужно
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
Carefully detach the negative wire from the battery terminal first.
Next, detach the positive wire from the battery terminal.
Один комментарий
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
