Введение
Is your switch unable to move due to a foreign liquid? Does the switch feel like its seated improperly? Check out this guide on removing and replacing the switch.
Выберете то, что вам нужно
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
Carefully detach the negative wire from the battery terminal first.
Next, detach the positive wire from the battery terminal.
Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
Remove the plastic barrier.
Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
Gently grab the main board by the exposed PCB.
Pull the main board straight out of the housing.
Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
