Введение
Speakers will sometimes rupture from extended periods of high volume. Speakers may also malfunction due to old age. Without a speaker, many devices can not be used. This guide helps you replace the speakers for the ComNet Ericsson Panther 600P.
Выберете то, что вам нужно
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Twist the antenna counter-clockwise to unscrew it from the antenna jack.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Locate the device's speaker inside the front panel of the exterior case.
Locate the display and speaker stabilizer.
Lift the stabilizer up from the bottom and pull the stabilizer out of case.
Locate the two 3.75mm screws holding the speaker to the exterior case.
Using a T15 Torx screwdriver, unscrew the 3.75mm screws.
Lift up on the bottom of the speaker to detach the speaker.
Pull the speaker out of the case.
