Compact Fluorescent Lightbulb CFL Lightbulb Replacement
  1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: шаг 1, изображение 1 из 2 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: шаг 1, изображение 2 из 2
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: шаг 2, изображение 1 из 1
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: шаг 3, изображение 1 из 1
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
Финишная черта
12 участников успешно повторили данное руководство.
WiseGeek
Участник с: 04/04/11
1 364 Репутация
Автор 2 руководств
Один комментарий
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 21
За всё время: 7,899
