Введение
You will need to assemble the proper tools shown in the first step of this guide before you continue forward.
This guide is meant to assist the reader with the proper steps to remove and replace the keyboard of the Compaq Evo N1000v device.
Запчасти
Никакие детали не требуются.
Carefully remove the screws located inside the red circles.
  • Carefully remove the screws located inside the red circles.
Добавить комментарий
Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
  • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
  • Push down on the spudger to lift the LED display panel upward.
  • Do this on both the left and right sides of the device as shown in the images.
  • Completely remove the LED display panel from the device.
  • Left the keyboard up from the back end as shown in the image.
  • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
  • Repeat this action on the right side of the lock.
  • Pull the keyboard upward to remove it from the device.
  • Repeat these steps in reverse order to install the new keyboard.
Заключение
ryan
Участник с: 12.03.2014
470 Репутация
Автор 4 руководств
Команда
University of Maryland, Team 2-1, Vijaybhaskar Spring 2014 Member of University of Maryland, Team 2-1, Vijaybhaskar Spring 2014
UMD-VIJAYBHASKAR-S14S2G1
3 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 184
