Введение
Over time, the LED cover on the Compaq Evo N1000v may become cracked, loose, or discolored due to regular wear and tear. This repair is typically needed when the cover is visibly damaged or no longer holds in place, which can affect the appearance of the laptop and possibly interfere with the power or status indicators. This guide requires only basic tools and no advanced technical skills. While the repair is relatively straightforward, care must be taken when removing nearby components to avoid damage, as the plastic casing can become weak over time.
Выберете то, что вам нужно
Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Еще один человек закончил это руководство.
