Введение
Carpal Tunnel Syndrome is one of the worst outcomes that comes from poor wrist placement. Wrist placement that comes from typing on a keyboard, or more specifically, on a laptop keyboard. The purpose of the palm rest is to ensure proper wrist posture, and its purpose is dedicated to ensuring that no lifelong inconveniences come of it.
In this guide, you will be guided step by step in order to properly disassemble and replace the palm rest for a Compaq Evo N1000v.
There is no special skillset required for this fix, besides a slight learning curve that comes with the learning the surface-level intricacies that come with opening up a laptop.
Выберете то, что вам нужно
Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Remove the battery.
Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
Flip the laptop over again so the top is facing up.
Open the laptop screen and face it towards you.
Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
Еще один человек закончил это руководство.
