Введение
A guide on how to remove the Top Cover.
Запчасти
Детали не указаны.
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
While holding the Pause and Scroll keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Locate the fan near the top left corner. It has three colored wires: yellow, red, and black.
Disconnect the cable connecting the fan to the system board.
Remove battery and then remove screw in metal support on case edge
Flip the computer top side up with the front facing you.
Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
Disconnect the microphone cable from the system board.
