Введение
A guide on how to remove the Top Cover of your Compaq Evo N1000v laptop.
Выберете то, что вам нужно
Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
Remove the battery.
Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
Flip the laptop over again so the top is facing up.
Open the laptop screen and face it towards you.
Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
Remove the three TM 2.5 mm x 5.0 mm screws that secure the top cover to the base.
Lift the top cover straight up about one inch, then slide forward until the microphone cable is exposed.
Disconnect the microphone cable from the system board.
