Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
To get farther inside your laptop, you now have to remove the top cover.
Выберете то, что вам нужно
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Pry up the top plastic cover using a spudger.
Under the screen there are two tabs that need to be pushed in.
4 участников успешно повторили данное руководство.
