Введение
The hard drive is a vital component which stores the operating system and all your data. If your drive is broken or has errors, you'll probably have blue screen errors.
Выберете то, что вам нужно
Shutdown the computer.
Remove all external devices.
Unplug the power, and any other cords, from the laptop.
Turn the laptop upside down, with the front towards you.
Slide the battery release latch to the left until the battery pops up.
Lift the front edge of the battery pack and swing it back to remove it.
Loosen the two 5mm Philips #1 screws that secure the hard drive cover to the computer.
Lift the left side of the cover and swing it to the right to remove it.
Grasp the black Mylar tab on the hard drive frame and pull firmly straight up until the hard drive disconnects from the computer, and remove it.
Remove the four 4mm Philips #1 screws, two on each side, that secure the hard drive frame to the hard drive.
Lift the frame to remove if from the hard drive.
