Compaq Presario V2414NR Keyboard Replacement
Выберете то, что вам нужно
  1. Compaq Presario V2414NR Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Keyboard Replacement: шаг 2, изображение 1 из 2 Compaq Presario V2414NR Keyboard Replacement: шаг 2, изображение 2 из 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Keyboard Replacement, Optical Drive: шаг 3, изображение 1 из 2 Compaq Presario V2414NR Keyboard Replacement, Optical Drive: шаг 3, изображение 2 из 2
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Keyboard Replacement: шаг 4, изображение 1 из 3 Compaq Presario V2414NR Keyboard Replacement: шаг 4, изображение 2 из 3 Compaq Presario V2414NR Keyboard Replacement: шаг 4, изображение 3 из 3
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
  5. Compaq Presario V2414NR Keyboard Replacement, Keyboard: шаг 5, изображение 1 из 1
    • Remove the two 4mm Philips #1 screws that secure the switch cover to the computer.
    • Turn the computer display-side up with the front panel toward you.
    • Open the computer display as far as possible.
  6. Compaq Presario V2414NR Keyboard Replacement: шаг 6, изображение 1 из 1
    • Insert a plastic opening tool into the slots located behind the [F5] key and lift the front edge of the switch cover until it disengages from the computer.
    • Insert a plastic opening tool into the slots located behind the [Insert] key and lift the front edge of the switch cover until it disengages from the computer.
    • Remove the switch cover.
  7. Compaq Presario V2414NR Keyboard Replacement: шаг 7, изображение 1 из 3 Compaq Presario V2414NR Keyboard Replacement: шаг 7, изображение 2 из 3 Compaq Presario V2414NR Keyboard Replacement: шаг 7, изображение 3 из 3
    • Remove the four 3mm Phillips #1 screws that secure the keyboard to the computer.
    • Swing the rear edge of the keyboard up and forward until it rests on the palm rest.
  8. Compaq Presario V2414NR Keyboard Replacement: шаг 8, изображение 1 из 1
    • Use your fingernails or two plastic opening tools to push the white portion of the ZIF connector towards the hinge of the computer.
    • Remove the ribbon cable from the ZIF connector.
    • Remove the keyboard.
Заключение
Rylie Schmidt
Участник с: 04/19/15
765 Репутация
Автор 7 руководств
Команда
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Участник UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 10
За всё время: 295
