Compaq Presario V2414NR WiFi Card Replacement
Выберете то, что вам нужно
  1. Compaq Presario V2414NR WiFi Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR WiFi Card Replacement: шаг 2, изображение 1 из 2 Compaq Presario V2414NR WiFi Card Replacement: шаг 2, изображение 2 из 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: шаг 3, изображение 1 из 2 Compaq Presario V2414NR WiFi Card Replacement, RAM Cover: шаг 3, изображение 2 из 2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: шаг 4, изображение 1 из 2 Compaq Presario V2414NR WiFi Card Replacement, WiFi Card: шаг 4, изображение 2 из 2
    • Loosen the 5mm Phillips #1 screw that secures the Mini PCI compartment cover to the computer.
    • This screw is captured to the cover panel.
    • Lift the rear edge of the Mini PCI compartment cover, and swing it forward to remove it.
  5. Compaq Presario V2414NR WiFi Card Replacement: шаг 5, изображение 1 из 2 Compaq Presario V2414NR WiFi Card Replacement: шаг 5, изображение 2 из 2
    • Make note of which cable is attached to which clip on the WiFi card before disconnecting the cables.
    • Disconnect the wireless antenna cables from the WiFi card by prying gently upwards on the metal part of the connector with a spudger or plastic opening tool.
  6. Compaq Presario V2414NR WiFi Card Replacement: шаг 6, изображение 1 из 2 Compaq Presario V2414NR WiFi Card Replacement: шаг 6, изображение 2 из 2
    • Use your fingernails, or plastic opening tools, to spread the metal retaining tabs on each side of the WiFi card outwards until the card pops up.
    • Pull the WiFi card out of the socket at the same angle it is now oriented.
    • When reassembling, align the offset notch on the WiFi card contacts with the tab on the socket and insert at a 30 degree angle.
Заключение
Rylie Schmidt
Участник с: 04/19/15
765 Репутация
Автор 7 руководств
Команда
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 Участник UMass Dartmouth, Team 2-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G1
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 323
