Введение
How to remove and replace the LCD display panel
Выберете то, что вам нужно
There are 6 screws holding on the display bezel, hidden behind screw covers
Remove the screw covers with a spudger or small flat blade screwdriver
Remove the screws with a phillips #1 screwdriver
Use your fingers to pry off the bezel at the top and sides first
You may need to use a spudger or flat blade screwdriver at the bottom edge around the hinges
Remove the two side screws at the top of the panel first
Then remove the two side screws at the bottom. It may be necessary to angle the display away from the back cover to reach these well
Lay the panel down on the keyboard
Remove the tape covering the display cable connecter
Remove the display cable from the panel
5 участников успешно повторили данное руководство.
2 Комментариев
Do you know where I can buy the replacement screen being replaced?
Laptop panels are fairly generic, you don't need an HP screen for an HP laptop for example. There are numerous places selling them including laptop screen.com, or on eBay. Be sure to get the same size, resolution, backlight type, and connector as the screen you are replacing. Often there is a sticker on the back of the screen with a model code you can search for (e.g.. LP140WH3)
