Введение
Follow this guide to conduct a cylinder compression test on a 2019 Echo Power Pruner model PPT-2620.
Выберете то, что вам нужно
Pull the spark plug cap straight off of the spark plug.
Use a 5/8-inch spark plug socket to remove the spark plug from the engine.
Check if the spark plug is fouled and replace it if necessary.
Follow the instruction provided with your compression test kit to connect a compression tester to the cylinder.
Pull the starter 5–10 times to build pressure in the combustion chamber.
2 участников успешно повторили данное руководство.
