Введение
You will need to access the battery compartment before you can change the battery or remove the larger back casing. To remove the battery casing, you will need a Phillips head screwdriver.
Выберете то, что вам нужно
Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
Slide the cover off and remove the battery.
