Введение
The product name and model number is the Container Store Big Flat Bungee Office Chair with Arms model number 10052635. This guide will teach you how to repair a loose arm on a swivel chair like the one in this guide. Step 4 requires you to check if the hole for the screw has become enlarged. If it has a larger hex screw may be needed.
Выберете то, что вам нужно
Remove the screw caps on both sides of the arm of the chair.
Use an Allen wrench to remove the arm to make sure the plastic hole for the screw has not become enlarged.
Почти готово!
Финишная черта
