Введение
Overheating laptops can be a serious problem. Luckily devices like the Cooler Master Laptop
Fan can help keep your laptop cooler than the fans in your laptop can. This helps extend the life
of your laptop and allows better performance for your laptop as well. However even laptop fans
can fail and need to be replaced.
Выберете то, что вам нужно
Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
On the bottom of the base locate the screw holes under the sticker on the base.
Unscrew the three fan screws.
Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
2 участников успешно повторили данное руководство.
