Введение
Step by step process on how to remove back housing that must be removed before further internal repairs can be done.
Выберете то, что вам нужно
After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
6 участников успешно повторили данное руководство.
