Введение
Use this guide to replace the daughterboard in your phone.
Выберете то, что вам нужно
Turn the phone with the back cover facing towards you.
Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
Find the gap on the bottom of the battery.
With a tool or with your hands, pull the battery upward and set it aside safely.
Remove all fifteen screws using the Phillips #000 screwdriver.
Remove the back panel after all screws are removed.
Disconnect the metal cable using the plastic spudger.
The remove the glued down speaker from the backing.
Disconnect the little black wire from lower logic board.
Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
