Coolpad Defiant Daughterboard Replacement
Выберете то, что вам нужно
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: шаг 1, изображение 1 из 2 Coolpad Defiant Daughterboard Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: шаг 2, изображение 1 из 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: шаг 3, изображение 1 из 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: шаг 4, изображение 1 из 2 Coolpad Defiant Daughterboard Replacement, Daughterboard: шаг 4, изображение 2 из 2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: шаг 5, изображение 1 из 3 Coolpad Defiant Daughterboard Replacement: шаг 5, изображение 2 из 3 Coolpad Defiant Daughterboard Replacement: шаг 5, изображение 3 из 3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: шаг 6, изображение 1 из 1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Заключение
Elijah Gastin
Участник с: 09/21/18
100 Репутация
1 руководство автора
Команда
University of North Texas, Team S5-G6, Thompson Fall 2018 Участник University of North Texas, Team S5-G6, Thompson Fall 2018
UNT-THOMPSON-F18S5G6
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 450
