Введение
Have you tried everything and your camera just won't turn on? No worries! This guide will show you how to successfully remove your battery.
Выберете то, что вам нужно
Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
Next, remove the 2mm screw from the right side.
Lastly, remove the 3mm screw from the bottom of the camera.
Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
Next, use the same small plastic opening tool and gently pull out the battery.
To reassemble, follow the steps in reverse order.
3 участников успешно повторили данное руководство.
