Введение
Broken screen, cracked screen, no screen? No problem! If you own a Nikon Coolpix digital camera and are experiencing a screen cover problem, this guide will surely help.
Выберете то, что вам нужно
First make sure the camera is powered off.
Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
Next, remove the 2 mm screw from the right side of the camera
Remove the 3mm screw from the bottom of the camera.
Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
Be sure to remove the battery before continuing your repair.
With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Еще один человек закончил это руководство.
