Выберете то, что вам нужно
First make sure the camera is powered off.
Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
Next remove the 2 mm screw from the right side of the camera.
Remove the 3mm screw from the bottom of the camera.
Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
Почти готово!
Заключение
